How to fit a C Tek Trickle charger
Percival
Kent
Just feed the cable over headlight area and shut the bonnet? I do and have no problems.........?
I do the same I have a male and female connection with a cover t put in when not in use, I run the wire with the charger to the area where the coolant bottle is as there's a lot of space here then run the mains lead over the light and tuck the lead to the corner near the inner wing bonnet shuts fine and then plug it in the power socket....
Hope this helps you out and fellow RCZers..
Stay safe and stay lucky 🍀
