Hands Free Call Volume
OkeyStokey
I have looked in the manual, done a quick search on here & on Google but had no luck.
Does anyone know how to change the volume of the "ringer" when you receive an incoming call on the hands free bluetooth system?
I have the RD5, and it is deafening whenever you get a call.
chrismac
A trick that works on many systems is to lower the volume when in use, the radio, CD player etc should remain unaffected.
Give it a try.
Yes as Chris Mac says plus this is the way to change all volume settings, but it must be in use at the time, ie. if someone rings the ring volume can be changed by adjusting the volume before accepting the call, then whilst on the call, change volume up or down to suit your comfort. Other volume settings will not be changed.
OkeyStokey
Thanks for the help.
I will give it a try at the next opportunity.
