Fuse Location for Rear Tail Light
Hope Island RCZ
Gold Coast
Hi, the left rear tail light has gone in my 2013 RCZ. Before I replace the bulb, I wanted to check the fuse, but it’s impossible to find which one it is. I’ve looked at every instructional website but none list the rear tail lights. Any clues?
probably bulb has died a death or another issue could be a grounding (earth) fault
Voltage test on the connector ?
if its a fuse then it could even be fed from another circuit/relay?
I believe that it is like other peougeot model if one of the back lights is not working and the bulb is OK it's on the same in line circuit as the number plate bulbs and if on of the bulb blow the back light at that side stops working I know this as the 307cc is like this %100 so could be same on the RCZs...
Hope this helps you out and other RCZers...
