Folding Door Mirrors
Phew lol also is the Sat Nav touchscreen ? Is it worth the extra
Sat Nav is NOT touch screen, is it worth the money IMO Yes.
Is sat nav worth it depends on weather u get lost often. The £49:99 Tom Tom on my iPhone is all I've ever needed
Fully support this. It's worth it foe the increased cab appeal alone :thumbup: That's without the added benefit of the sat nav functions :lol: Plus it probably still adds tyre inflation sensors too and they cost approx £100 each if you were to buy them separately.
I've noticed that when I select reverse gear and the electric door mirror switch is selected to the drivers mirror. The mirror glass moves down to aid in parking. But when I move the switch to the passenger mirror the glass doesn't move .
Is this normal or should I book it in at peugeot.
My mirrors dip on both sides when the switch is placed in the respective position.
I don't think it should matter, but have you tried taking it out of gear, flicking the switch to the left then engaging reverse again. Like I say though, I don't have to do this in mine :eusa-think:
Are you sure you're selecting passenger side? There are three options 1) Drivers side, 2) neither, 3) Passenger.
You have to go through the middle option to get to the passenger side!
If you already are then, yes, it's a problem that the dealer should fix under warranty.
I've tried moving the switch from the drivers side to the passenger side.
Drivers mirror dips but passenger side doesn't.
Looks like its a trip to the dealer.
Will keep you posted on the outcome.
Have you actually set the mirrors to dip when that side is selected? I have found mine intermittently forget the setting and so have to put the car in reverse and manually adjust them to dip as I require. Then when a forward gear is selected the mirrors will raise up as normal. May be worth trying to reset it.
Just been down to swansway peugeot in chester. The manager actually dealt with the issue as he drives a z himself.
The problem was the passenger mirror was set so low that when I selected reverse the mirror had nowhere to go.
I automatically thought this had broke.
Anyway problem sorted . Thanks for all of the replies .
:grin:
:grin:
Good stuff :thumbup:
Sometimes it's the simplest things. Glad to hear that it was easily resolved.
Regarding the sat nav system, Even if it was touch screen it's too far away to use don't let that put you off though its pretty good all-round once you get used to it.
I would rather have it than not especially the NG4 with its hard drive.
Opal white GT with type 1 matt stripe.
I use my Galaxy S4 for the Sat Nav I assume, if I link it up via Bluetooth it will read me out the directions anyway ? also can you change tracks when connected via Bluetooth via the steering wheel ?
