Fob battery replacement
Heanster
Knutsford
I have two keys but one is proving erratic which I have put down to being the battery on it's way out. Question: If I replace the battery does the key have to be re-programmed? Any help with the process much appreciated 👍🏻
No they are preprogrammed to your car its a straight swop over I have changed 1 of mine with no issues there are a few vids on YTube if you need any help
If you've put a new battery in the keyfob, the owner's manual tells you you should reinitialise it afterwards:
REMOTE CONTROL PROBLEM
Following disconnection of the vehicle battery, replacement of the remote control battery or in the event of a remote control malfunction, you can no longer unlock, lock or locate your vehicle.
First of all, use the key in the lock to unlock or lock your vehicle.
Then, reinitialise the remote control.
Reinitialisation:
Switch off the ignition.
Turn the key to position 2 (Ignition on) .
Press the closed padlock immediately for a few seconds.
Switch off the ignition and remove the key from the ignition switch.
The remote control is fully operational again
ONLY AEK
greece
I have the same problem
my key just stoped working
i will try a new battery
"Press the closed padlock immediately for a few seconds." with this you mean, the button that locks the car?
ONLY AEK
greece
Has anyone replaced the key fob?
i found this in alli express
which is c0523 like our key but the blade has the code hac/hu83 instead of HCA that mine has
Does enyone know if it fits?
It also says HCA on my blade, but for sure it's different from yours.
If the case is changed, the old blade should be reused. It is disassembled by removing a small pin that it has.
Yes I have changed all mine they do offer a cutting service too I did get it cut just by sending them photos of the blade when it arrived just changed the circuit board and all working fine... I did have it posted to a friends address for obvious reasons...
ONLY AEK
greece
where did you send them the photos?
i sent them a message through alli messages but noone read it
Did you see where there key cutting service was you have to go through there and get done with key Fob...
£3.51 18%OFF | jingyuqin Extra fee for CNC Cutting Slicing Sting Cut Engraved Key Blade Service please contact with us before purchase
ONLY AEK
greece
Yes i putted in the order the cutting service
i can't find an email for them
only the contact through alli messages
If you read down the link I have posted it tells you what you have to do just scroll down and read what it says just double checked and it is there for all
