Fault Code & Other Weirdness - Advice Needed Please!
tianorth said:
As these cars are run by computers they only understand yes or no.
What the car sees is the driver is an idiot and I the computer knows better.
If I was 2retro I would be suing my car for slander :lol:
I think my car might have a sneaking suspicion that I could be the Stig :eusa-whistle:
That's lucky because if your car was German - it might think you're DAVID HASSELHOFF - what's that Kit !?
:D :beer:
Hmm, I’m thinking maybe I need an OBD Reader now while mine is covered under the extended warranty.
Btw that hp pump on eBay says it isn’t compatible with mine either, so that’s 2 of the 4 variants it’s not compatible with :eusa-think:
Ok so here’s one that is compatible with the thp 200 and the R, again any decent Indi garage could install this and you would be quids in compared to £1400 at dealers :thumbup:
Nemi
Lithuania
Guppy said:
I have the same problem (code P0087).... best case senirio new fuel filter £30, worst case sinario new high pressure fuel pump £1400 fitting included.
Does THP 200 have replaceable fuel filter? :eusa-think:
Some THP low pressure fuel pumps, specially in African versions, come with an external fuel filter that can be replaced. It is a good idea to replace that every 20.000km. European versions have a filter built into the fuel pumps housing and it cannot be replaced.
