Error for lights
Ross_Russev
Bulgaria
Hi there!
It might have been talked over already, but I couldn't find the thread, so here's my issue:
- I have 2012 HDi GT with vision pack, and in diagbox I have error saying "Open circuit in front right and left side lamps"
Point is, all bulbs are there and functional, so my question is - to which exactly bulb is the diagbox referring?
Open circuit means a break in the circuit usually faulty or broken wiring maybe the cause or a bad ground wire
Ross_Russev
Bulgaria
Thanks, but does it mean faulty wire on these specific bulbs and if yes ( which I presume is the answer ) - to which bulbs is the bloody diagbox referring - the yellow directional ones or the day-lights / main beams? I don't believe it to be the xenon ones ...
Maybe do a BSI reset as this controls the lights (Software issue?) Check the connectors for a voltage reading with a Multimeter? Possibly be a low battery problem?
