Driver's door card
wilbur
cardiff
Any info on how to remove door card the motor is spinning and moves slowly but grinding sound I thought it was ice in the motor but I will look before buying a new regulator
These might help
thanks
Pedro you are a star
I forgot to mention if you have already stripped it out then tis post may be too late to be of any use but the plastic chrome door handle cover unclips from the top downwards because as you reach say 2 inches from the bottom it slots into a small housing so just gently lever it upwards & outwards until it becomes free as others have actually found using too much force the clips snap off resulting in buying a new cover so be careful
