Dipped beam headlights keep blowing
RCZ-Trev
Streatley Beds
Hi.
Every 1- 1/2 to 2 months one or the other of my dipped beam headlight bulbs keep blowing . Has anyone else had this problem? If so what can i do about it. Its becoming expensive. The only upside is that I am getting quite quick at changing them.
Assuming its not moisture in the lamp or bulbs it may be the switch-headlight relay or wiring fault other one to watch for is bad earths (grounding fault) you may need to check wiring from the fuse box into the lamp connectors
