Coolant sensor
metromrx
london
hi I have been to a garage, who want to charge me 180.00 to have coolant sensor replaced, they say the have to drain coolant. is this correct and is 180.00 sound right please
Is this the coolant temp sensor or the level sensor?
metromrx
london
Hi the message says top up engine coolant plus message says engine fault need repair. garage says sensor needs changing.
You can disconnect the coolant level sensor it’s located in the expansion tank and see if the warning message disappears you may have to clear the fault via a scan tool though.
If it is this it’s so easy to replace.
travelswithanrcz
Edinburgh
I believe if you're replacing the sensor altogether, the coolant reservoir does need drained entirely. My stupid sensor likes to pop up every now and then to tell me to top my coolant up, but the levels are absolutely fine so I'm just ignoring it for now.
No idea on the cost of that being done unfortunately, but there's a decent how to video on youtube here: 1.6 THP coolant sensor (1306J0) replacement 🔧 - YouTube
Assuming its the level sensor try cleaning all the gunge off the tips of the sensor if your replacing it you only need to remove around half a tankful I used a syringe to syphon off the amount needed to change mine & you need to replace it with the same part a Bosch or Cartier as some cheaper OEM parts won't be compatible
sheymoose
belfast
If I just want to disconnect the sensor do I have to drain the coolant?
Nemi
Lithuania
Just unplug the cable that is connected to the sensor, no need to drain the coolant.
Macro Tsai
Taiwan
液位採集器的探棒我以前有過經歷,我拆下採集器後切開外殼,液位標記是焊接在電路板上,焊點長期關閉下打開,重新焊接後安裝回去就好了
。這樣可以免費修復。跟前面分享的影片比較,我的亮點特別長,但功能都一樣。
Kenneth
Ayrshire
It’s a ten minute job to replace. I’ve got a syringe with a pipe on it for unclogging the fridge drain and used it to remove enough coolant to get below where the sensor is. Just put it back in. The sensor will fail again in due course as they all do. I kept the original and re soldered the part where the pins hit the circuit board. It’s working as well. They seem to fail at that point. It’s got a decent blob of solder there so it might last slightly longer. Dunno. You have to cut it all open and glue it all back together. A faff. But I thought I’d try it anyway. I’ll see how long it lasts when the new one has failed. And it will 😁
Or, just do what peugeot tell you to do and unplug the sensor and tape it all up and check your levels the old fashioned way.
