Thank you very much appreciate the response, I will know more on the 10th JanSorry, I haven’t been on the forum for a while.
As NF7 has said, I had this problem for quite a while - several months before I took it to the garage. I thought it seemed to be getting more frequent, and it had only done it in first gear to start with, but then also reverse.
As previously posted, they replaced everything under extended warranty, even though the clutch plate was hardly worn, they said it made sense to replace the lot while doing the DMF.
