Car won’t turn over😡
Malcf70
Stockport
Hi all,
Had my z for just over a year and no problems apart from suspension bushes and a spring, got in car this morning turned the key and nothing dash lights up and that’s about it !
Had breakdown cover come around and they said maybe immobiliser but couldn’t get it going !!!
Any ideas anybody please!!!
Is the battery dead or been disconnected?
Malcf70
Stockport
Not as I know been fine up until this morning dash lights up telling me economy mode which is strange then dash lights go blank just engine light and handbrake light on !
Clocks gone back to 2017 ?
It does sound like the battery. Could do with checking the charge level if you can. How old is it? They have been known to suddenly pack up and produce symptoms such as yours...
Malcf70
Stockport
Hi , it’s a 2011 car don’t now the age of the battery tho , tried to have a look at the battery but seems well hidden and has a weird compartment of wires and fuses over the top of battery!
Almost 100% battery. Probably original, although if it was replaced after @ 5 years (recommended life span, but most last much longer) it would still be nearly 6 years old now, so even on its 2nd battery it might need replacing.
Most places that will sell you a battery will test your old one for you too.
Malcf70
Stockport
Hi thanks all,
Had the car towed too the garage fault was starter motor, which the the mechanic did and said it was buried at the back of the engine which took some man hours 😫
So it was the starter motor and not the battery failing to turn the starter motor? Weird.
The battery-starter motor & alternator are all linked together thereby if one is failing it will affect the other 2 as the circuit will be or breaking down but let's not forget a faulty battery module in the diagnostics
TimRCZ
Welwyn Garden City
Had this same problem last year. AA couldn't diagnose (didn't try actually). Battery was tested ok, turned out it was a faulty exhaust camshaft de-fazer solenoid, WeverTF that is! Anyway 80 well spent quid to my clever local back street specialists and back on the road in no time!
Blooming auto spell correct, it’s always changing “starter motor” to “battery” when I type it too 🤣
The battery module has come up quite a few times and creates a similar fault and they’re in excess of £400 I believe so I bought a spare from my local breakers 👍
