Barring high mileage elongation sure its not the tensioner which can & will go before the chain starts its death rattleMy car needs a cam chain doing does any one no what price Peogout will do the job for ? I will get my front discs an callipers sorted at the same time ,
Ps what do you think to a go fund me page
I suspect that is just the chain kit as in the earlier variants it was recommended to change both cam sprockets & the crank seal plus the pulley bolt when replacing the chain set up because the cogs teeth wear out at a unbelievable rate on these engines & I suspect its the same with the facelift models also which may contribute to so many unexplained chain failures aside from poor oil servicesMy wife says you don’t stop tinkering and when are you gonna look at mine I tell her soon ! B class merc ) Ps an I had a accurate quote back from Peogout in Norwich for the cam chain to be done … an you need to be sitting down £1,239 ouch , covid is to blame for the prices going up .
I wish they would change the record
