Broken wire on battery fuse panel
RCZKam
Was about to change my battery and noticed a torn wire going to the plug on the battery fuse panel. I haven’t got a wiring diagram and can’t seem to find the equivalent wiring diagram from a 308 as I’m assuming they share the same loom
Trying to narrow down my irregular air con issue
Colours from top to bottom are thin light blue, thin dark blue, thick beige and thick pink
The one in question is the second one down the thin dark blue almost dark grey in colour
Does anyone know where this goes to or has a wiring diagram handy to decipher?
2012 156thp
Is the cable cut or has a bite in the insulation?
It doesn't show up well in the photo.
If it only has a bite you can finish cutting it, solder it with tin and slide a heat shrink wrap
RCZKam
Definitely more than just the insulation
I found the battery fuse diagram and looks like it’s the dual function brake switch as number 1 and 5 are not used and mine is an automatic
I’ll repair this wire and get the battery changed :)
