Too good to be true? Lock went AWOL again so was a case of strip down & test first then grease the cogs & worm gear which appeared to be malfunctioning ?
Lock seems to be working fine now on manual but it was a pig to dismantle as it has offset pressure clips on the sides & you need to slightly lift the cover over the plug socket to free it completely but the bottom outer casing is plastic so extra care is needed ( bayonet clips could snap off very easily) !
