Running on 3 cylinders would cause limp mode as unburnt fuel would enter the exhaust & be picked by on the Upstream Lambda sensor which would alert the ECU the combustion cycle is out of sync ?
You need all four cylinders firing for the ECU to correctly calculate the exact Fuel /Air ratio for combustion if one plug is misfiring or dead then its into limp mode to try & stop serious damage happening as in it disables the Turbo etc
