Aircon not working?
Hi guys,
Wondering if anyone could help me.
The aircon system is not working on my RCZ.
At workshop we put new gas on it, but we found out that no energy reaches the aircon compressor, so obviously it does not engage.
We checked the fuse panel, and fuse is ok, but also no energy there!
My local workshop suspects the fuse box is damaged, as they told me this is called BSM module (or something like that) and it usually gets damaged.
Any ideas what it could be the problem?
We run out of ideas. Also PP2000 does not show any error.
No idea if it would help or not, but you could try a BSI reset. I know it has resolved some weird and wonderful issues in the past. :eusa-think:
equipment is switched off.
ignition.
15 seconds.
not open doors.)
BSI related items.
Hope this helps
I was having the same problem. I had every check done by Peugeot but still nothing got sorted.
Took it to an auto electrician and he found the problem in 2 minutes. It was a loose wire going to the compressor...
Sounds easier (and more likely) than the BSI reset ;)
Will try the above suggestions.
We could even try to power directly with 12V the aircon fuse, but we didn't do it, because we were afraid burning something..
Try the yellow connector joining the car wiring move it around a little and you will hear the compressor kick in. That's where my problem lies
