ABS failure
Darren
Hertford
Has anyone experienced ABS failure on their RCZ , is it a common issue
I have not come across one yet unless there is a post on here it may well be a ABS wheel sensor or possibly crap around the pick up ring ? if its a ECU warning from the dash then that may well indicate it is a sensor but you need a scan to check for a fault code on the braking system get back on if your struggling ?
Good luck
Not heard of this being a common issue
