Turbo boost pressure settings ?
Grimreaper
Suffolk
Hi all,
What are the turbo boost settings for standard 200Bhp max & min please.
Can’t seem to find info.
The maximum turbo pressure is stored in the ECU maps and does not have to be just one pressure, it varies with revs or other factors.
It's not as easy as changing a single value.
rczgod
Essex
Yes but you can increase/ decrease boost with wastegate actuator arm
That could be done in older cars without so much electronics, when the membrane of the wastegate actuator was simply connected to the intake manifold.
Now by doing that the system detects that the pressure is not as expected, the engine fault light comes on and it goes into limb mode.
If you want more boost pressure, you should ask for a engine remap in a specialized workshop.
