TPMS control module
Dave jc
salisbury
Can anyone tell me where the tpms control module is located.
not the pressure sensors, they are all new and working.
after 8 10 miles i get a warning tyre pressures not monitored, after 5 seconds it clears,
front off side is saying fault, I have changed the TPMS three times in that wheel, new tyre ,changed the wheel, and replaced the ABS sensor.
any advice would be appreciated.
EddieJ
Belfast
Might be it’s not programmed in correctly. If you have a tpms activator/reader and a reasonable scan tool you could activate them one by one and confirm the correct id is in the tpms module for each wheel.
Also try moving the wheel that shows up as faulty to the rear and write the change to the module.
i have the exact same going on with my 308cc, though annoying the car is pre 2012 when tpms became an mot thing so i plan to do something when the weather eventually picks up. As you say, ding and warning for a few seconds is annoying, but i have learnt to ignore for now.
