Hi all, have not posted for a while. Having issue with my THP200. Info below.
Early Feb, changed the oil. I had driven it previously to get the oil up to temp.
-Drove the car up a ramp and fan went crazy. When I drove it before doing this I didn't notice the temp gauge going over 90
-Changed oil and got MOT done and it was ok for a couple of days
-It then started doing it again once or twice
-On the last drive I did, the fan kept going full blast and noticed the temp gauge would go over 90c then go back close to 90c before going up again. Unfortunately, I couldn't easily stopped so probably drove it like this for over 40-60 minutes in total
-The next day I tried to start the car and it wouldn't start. It cranked but would not start
Hooked up my diagnostic and first I got the following.
-P0117 coolant temperature signal intermittent
-F40A oil gauge fault
-F303 Fault: configuration
I tried BSI reset multiple times. Made sure battery is charged, now I keep getting the following error codes.
-F5FF Unexpected re-initialisation fault coming from the BSI.
I've tried so many BSI resets but no luck, has anyone had similar issue?
Checked the battery with a multimeter and looks OK. Just in case I also swapped the battery on my key fob.
I do have some corrosion on the positive terminal, have cleaned it up but will try to clean it up more tomorrow.
Just wondering whether I have a corrupt BSI.
The car cranks up and engine is trying to come on but not doing it.
