Temp problems
Well that's another 3 days peugeot have had my Dolphin blue due to repeated temperature problems, they have told me that they had to replace the new temp sensor and harness as oil was getting in and shorting out the sensor ? Hopefully that will be the end to my issues diners crossed.
Hi sandymc with your temperature problems did the temperature keep flying up and down? I drove to work this morning temp started at 50 when I drove away and then started going up and down from 50 to 90 then to 70 to 50 then back up to 90. I took it for a drive this afternoon and same fault. I've already had the temp sensor changed when the engine warning light had come on and told me to turn the engine off.i haven't had the warning light yet.thankfully still in warranty and booked in at the garage
For Monday.have they told you what it is?
ELI2fly,
Yes that's what mine started to do and then in time the temp warning liven again, they told me that they had to change the harness as oil was getting in and shorting out the new temp sensor.
Oh really is yours still in warranty? It's was only 3 months ago that I had the temp sensor replaced I'm so surprised I'm having problems again.although I do love my rcz , seems to be a few electrical faults.
Thanks sandymc
I had that with temp sensor fault. It was intermittent though so would not replicate itself welch time I took it into the dealers. It wasn't showing any error codes either.
Ended up with a new sensor being out in and the wiring being rerouted.
Well Its been in today and I've been told they need it for longer.they said possibly the wiring loom.think it will be in for a couple of more days :(
Sounds about right wiring loom harness oil getting in and shorting the sensor out. :greetings-wavingblue:
Thankfully it's still under warranty.just going to miss it a lot :( hopefully no more problems.thanks for your help sandymc :)
