danieldavid
ok, in case anyone has the same issue, before you start replacing drive shafts..... i recently had a binding left brake which i freed off, by stripping and cleaning it, then the right one started binding the next day. I couldnt work out what the one noise per wheel rotation was coing from. Concluded it was firstly on the left side though it spread to the right as well, i was prising drive sgafts for front left.....then i thought of something...surely the noise wasnt the rubbing of the retaining clips on the front 340mm brakes. yes it was, on both sides, they hadnt quite been clipped in level and were catching on the interior of the aloy wheels. In case anyone has a strange noise that sounds like drive shafts, before you start stripping the front drivetrain. I found a case on line where someones wheel was causibng the actual noise after he had stripped the drive shafts etc and already replaced....
