starter motor wont turn
scorsyboy
Barnsley
I have lost some of the electrics,, no heater blower inside cab the lights to it dont even work and the starter motor does not turn not even a click as if its not communicating with the ecu
scorsyboy
Barnsley
I can hear a click coming from the bsi in glove box when i try and turn car over
scorsyboy
Barnsley
The click sounds like a relay maybe problematic or a ground fault also battery trouble either Battery itself or the Module can cause these issues if its faulty or failing if possibly get a battery test including the Alternator & Starter circuits all together
scorsyboy
Barnsley
I have changed fuse box and the battery module and it still wont turn over I have got all lights working on dash but it wont turn over. cannot here the fuel pump priming or anything. Economy mode is on too
scorsyboy
Barnsley
The starter motor works when I jump it but no start. Does the starter have a relay anywhere??
scorsyboy
Barnsley
Hi Pedro do you know if there is a relay anywhere for the starter?
