Some problem with window
Hello,
I have some problem with windows in my RCZ. The windows themselves open half way after I close them completely. Is it a fault to calibrate or something is damaged.
ONLY AEK
greece
Try to calibrate them yourself its very easy
You close them end keep pushing up the button for a few seconds
Repeat When opening them
How is your battery?
Maybe the anti pinch?
Could try running a cloth dipped in something around the seal.
I had it on one of my 407s.
Decided to do it just as it started raining.
Not impressed.
Most cars measure the resistance in the wires and motor etc. They have a tolerance level. So if our little ones decided to put their arms out the window and we close them as the window meets their arms the resistance goes up and then the car brings down the window as a safety measure.
Sounds like you need to reset. Bring window up and then hold the button up for 3-5 seconds should reset it and change the tolerance.
Cheers
There has been reports of water getting into the boot switch and doing funny things to unrelated items eg windows, central locking, etc.
