Rear wing fault.
Pookster85
Newton Abbot
Hi everyone,
Has anyone had an issue the their rear wing not deploying properly? It moves but struggles before eventually moving into position. An error message displays when I go over a certain speed activating the wing, stating its not working. Maybe it needs a clean has it does eventually does what it needs to?
Woodso
Huxley
I used to have a problem with mine struggling to open and close. This was because the drain holes were blocked and water built up and couldn't drain away. A clean out of the holes with a wooden skewer and some WD40 sorted that out. Maybe it is just a simple as that.
Pookster85
Newton Abbot
Great advice thank you, I will try that. Like I say, I works but struggles, so the WD40 should hopefully help!
