RCZ's seat problems, help.
tomflek
Finland
So my RCZ's regular (aka non-electric) seat is now stuck at bottom, rise function doesn't work, only 1 time I can pump that handle and then it won't let me go any further, then 1 pump down it goes and then it's simply fully down, what could have been gone broken and can I fix that myself?
Also seat starting to rock litte bit, where are those screws that I could tighten back so seat won't rock back and forth?
tomflek
Finland
No one hasn't really had these seat problems in their RCZ??
You would have to remove the entire seat and look underneath where the problem is.
tomflek
Finland
Oh okay, how big process that would be? And is there any guides how to remove it?
This is similar in almost any car, each front seat has 2 rails attached with 4 screws to the floor of the car, after removing the screws the entire seat with the rails are raised and removed, disconnecting the electrical connector that is usually located underneath.
