RCZ Temp gauge drops while driving & No hot air
Zain1999
Birmingham
Hi Guys
My RCZ 1.6 Petrol takes ages for the temp gauge to get to 90 degrees whilst driving but when the car is stationary it will increase to 90 relatively quick? Also no hot air blowing? It blows warm air but not hot like it should be.
Has anyone had a similar issue to this in the past and can offer some advice?
Many thanks
Probably Thermostat needs replacing which means the replacing the whole unit this issue can affect the Air con & interfere with the fuel air ratios?
Charlie1875
Birmingham
Yes classic sign of your thermostat stuck open, will only warm up when idling, had one on a Peugeot 208 gti (same engine) last month with exactly the same symptom, make sure the cooling system is bleed correctly as well.
Zain1999
Birmingham
I think first thing I will do is plug it in for fault codes but don’t anticipate any as there are no lights on the dash. Also AC seems to be working fine it’s just the heater not blowing hot. I’ll look into the thermostat housing so thanks for the pointer guys
Charlie1875
Birmingham
it doesn’t always throw up the engine management light but may have codes stored in the system, yes the thermostat is inside the housing and is a complete unit.
Buddy
Derby
I had this problem a couple of weeks ago and then it mostly returned to normal, since I was away from home I decided to change it when I got home and it has gone well until trying to fit a heater hose. The hose won't fit the connection point on the thermostat housing! It's a new housing from GSF and a new hose from Peugeot! It looks as though the original fitment housing and hose welded themselves together hence the need for a new hose and the reason the port on the original housing broke off when I was trying to remove it! Did Peugeot send me the wrong hose? And was the wrong hose fitted in the factory? I'm looking at making up a connecting piece for the original hose to get around the problem.
