rcz engine fault
Hi people.
I brought my rcz about a month a go and it is a great car.
However about 3 weeks after I brought it the oil light came on When this happened so did the engine light . So I topped up the oil with 1l it was fine the engibe light went off and now 2 weeks later there is no oil light but just the engine light on and it has lost most of its power .
Do you any idea why this is and is it a common fault
RCZ-Performance
Banbury
cory rcz said:
Hi people.
The EML can come on for many reasons so it is not possible to reply with what it could be. If you do not have a code reader for the car, then you will need to take it into the dealer or certified repair place for them to read the code to determine what the problem is.
Since you lost power it is in limp mode protecting the engine from further damage.
Only good manners to introduce yourself first. Common fault on the z, check technical section.
