Power Steering rcz gt 1.6 156
EddieJ
Belfast
Both mine have red in colour, but it’s the spec You need to be sure of. I flushed and refilled with this, but a decent autofactors will cross check for you.
There is something about mixing two types and it turning to sludge, not wanting to chance it is why I fully flushed first.
badger146
Dundee
Is this correct
EddieJ
Belfast
I can’t see the specs on it, but if you look at you handbook it will give you the spec to use.
As far as I remember the Total energy is the OEM recommended fluids.
Youd be as handy going into a local autofactors and getting them to cross check the spec and give you the right one, again from memory you’ll need 5.2L if going from fully empty after say a flush and drain.
EddieJ
Belfast
Sh1t, sorry, I have jumped threads somehow. That was in relation to engine coolant, as is the pic I put on above being comma g30 coolant.
Really don’t recommend coolant in the steering pump, might do a bit more than tick, for a wee while.
EddieJ
Belfast
Just went thru the books for both mine and it’s not listed. As PSA recommended Total I looked on their fluids checker for cars and got this info.
