Roberts1408
Hi,
Our RCZ 2013 has an engine fault message. It is not a low oil pressure alarm it just says engine fault needs repair. The codes on the diagnostic do not help as the fault code refers to a wet timing belt which I believe is not this model.
We have a low oil pressure warning if you allow the oil level to get to the minimum on the dip stick and start her up and leave on idle.
In a very short period of time we have had the vacuum pump fail, thermostat fail and now this oil system fault warning??
Any experience with this error message
