Newbie help with stereo.
Hi guys. Could you help. I just got my RCZ today but not had much time to play with it. In the time I had I couldn't find how to adjust the balance of the stereo. I have the mono display. Also managed to Bluetooth my phone to the car but how do you display the contacts and make a call? Cheers chaps
If you press menu on the right, next to the arrows, then select the menu with the phone and bluetooth symbol, the far right ine I think, then it should have call and directory.
To adjust the balance, keep pressing the musical note button in the middle of the stereo until you get to left/right and front/back
if you press and hold the two end buttons at the end of the stalks on he right hand side of the steering wheel the call list and directory come up on your screen.
Diggerd
Thanks guys, I'll give it a go when I get the chance. I'll let you know how it works out.
Thanks again guys.
I was able to adjust the audio balance by as you said, pressing the music note button. I was also able to bring up my contacts by again as you said pushing in the right bottom steering stork for a couple of seconds and contacts appear, then use the wheel on the stork to move one name at a time or by pressing the top or bottom edge switches on the same stork to go through the names in larger steps going to the first name in alphabetical order. Good stuff. :beer:
