I need some help, if someone had same problem.
My car had a big Oil leak from the cover. They also said turbo had a Lot of "play" and old. So I took the turbo to a reputable turbo shop and it was hybridated and they also did a new heat part, because mine was cracked. My car was running fine only with No Cat error ( because i have stock ecu file ). but no issues
Meanwhile in Peugeot dealer, they mounted the Turbo, new head cover, oil change, new spark plugs. And a bunch of new pipes and heat covers. New coolant.
But they delivered me the car with a P2263 code. High boost.
I have a wifi ELM, the boost on Car Scanner app, is showing minus something. and when I pull is doing 11, 12, 13 psi max, i think is stock boost.
But even doing only this normal boost, when comes near 4000rpm it goes into limp mode.
I want to remap but the guy doesnt want to touch the car with this problem. I dont think it's turbos company fault, because it's doing stock boost. The car before going to dealer, was running fine and if it was solenoid, I think it would to a lot more pressure, so i dont know what is causing this P2263 with 0.9 bar boost.
Any ideas?
I think everything it's connected at least from outside.
Any ideas?
