intermittent starting
Redleo
Kent
Hi, having a really annoying time with my RCZ 1.6thp 2011.
Parked the car up, returned from work and the car wouldn't start. Called AA checked over "Battery fault" sorry that is what you said 6 months ago so that is a new battery.
Bump started it, car worked normally for a few weeks . Then one morning wouldn't start. Towed to the garage no faults found still wouldn't start. Changed the battery ecu / brain still wouldn't start. Left for a few days then started first time. Only warning when not starting is ABS fault. Has any one else had similar.
Ruling out any electrical system fault on the starting circuits you need to scan then car it may possible be the immobiliser which can be a intermittent fault ?
