Ignition coil rubber sleave
Dennis
West Midlands
Hi Guys
Does anyone know if you can buy the ignition coil rubber sleeves for the 1.6 THP 200
The rubber sleeve is not a separate part, it does not have a specific reference, it is part of the coil.
Dennis
West Midlands
I had a misfire and called the RAC they came out and did some diagnostics and reported that the number 4 cylinder coil had failed he replaced the coil and solved the problem,as a result of this breakdown I thought I would purchase a spare one for any future failures this spare one sat in my boot for ages .later in the year I had reason to use the spare coil on opening the box I found that it comes with out the boot ,I tried to remove the old boot but because of its age this proved to be impossible consequently I have a new coil without a boot .
