Replaced my thermostat after receiving the correct one finally on the third time trying, but I don‘t think it’s opening, whilst stationary car got upto temp, was fully bled and hot air coming through cabin
Went for quick drive around block came back still all the same, only thing was I never heard my fan and lower radiator hose was not cold but certainly not lukewarm, top hose was warmish
Today took a little further (not much) but once upto temperature parked up and had mild smoke coming up under bonnet, checked and half my coolant was gone but the smoke/steam was coming from near battery/thermostat way plus a sizzling sound I presumed at this point my thermostat hadn’t opened so topped up coolant after cooling down and headed back home.
Few minutes from home the temperature reading started climbing above 90 (first time its ever done that) got to near 100/105 and I was home, again mild steam coming from thermo end so had a look and popped off some hoses and found this
The heater hose to the inlet for the matrix was off
If my thermostat for whatever reason wasn’t opening I take it whichever hose connection is the weakest one would pop off first?
Can you run without a thermostat? As I’m getting cheesed off with this now I’m wondering if I can butcher it out!
