gear shift indicator
Hi,
is the gear shift indicator on the 156bhp GT or the 200bh GT
Ive been reading the Peogot Rzc booklet that the dealer gave me, and all it say's is that it depends on which engine is chosen if the car comes with or wothout the gear shift indicator, but it does not say which engine does ave it ? Ive also read that the two different engines also have two slightly different displays ?
lionhart
manchester
the 156 has the small display and the gear shift indicator,the 200 has the large display but not the gear shift indicator,if you have sat nav in a 156 you also get the large display.not sure if this is the same for the diesel.but if i'm wrong i'm sure someone can post a reply. :beer:
i have opted for a 156 GT with sat nav, will i get the gear shift display
lionhart
manchester
not sure.only seen the gear shift indicator on the small disply,you need to have the top line split on the disply like the photo.not seen it on the large one. :eusa-think:both pic's are 156.
Hi there I have a 156hp engine and at first I did not have the gear change icon.but ask the dealer and they found out I should have it and turn it on now. So ask about
i have a 156 with sat nav and i DO have the gear change indicator.
hth
dave
This picture is of the large display on my HDi with sat nav and interior sport kit.
You can see the gearshift indicator in the top right suggesting changing to 4th.
I'm impressed, 35mph, 4th gear and doing a bit of photography.
xtof73
France
On the THP 156, the large display comes with the sport kit (the THP 200 has it since sport kit is included on the THP 200).
Don't know if you get the gear shift indicator with a 156 equipped with sport kit. Don't either for the HDI.
If you have the sports kit on the 156 then you get the large display, this DOES show the gear shift indicator
