Evening gents. I have recently purchased a lovely 2010 RCZ 156 GT and it already has me scratching my head
On starting and idling there are no bubbles in the expansion tank.
The engine pulls and sounds fine, no mayo under the oil filler cap. No white smoke.
Sat idling the temp gauge will go up to 90 and sit there perfectly normally. No heat out of the vents.
When moving the temp gauge goes steadily down and will either stay at rock bottom or hover around rock bottom. No heat out of the vents.
On turning the car off and checking the radiator pipes both top and bottom are equally warm/hot.
On start up I get the engine fault needs service message every time, which I hope is related.
This sounds like a dodgy heater matrix, thermostat or temp sensor right…or all three of them?
Confusion is that I do not understand how both top and bottom radiator pipes can be warm/hot and still not get any heat out of the vents?!
Any ideas guys?
Thanks in advance
Karl
Any ideas guys?
Thanks in advance
Karl
