Engine management 1 & 4 cylinders
LACEY
Dundee
Could anyone plz help my 2012 RCZ 1600 .....having problems with a missfire when the outside temperature is cold , put it on diagnostics machine came up problem with cylinders 1&4 , new spark plugs , swapped coils round , still came up problem with 1&4 :roll: any advice where to go next would be much appreciated
Could be a multitude of things, possibly carbon build up on intake valves what’s the mileage? And once warm does the car run fine?
A failing HP fuel pump usually throws up a misfire on #4 cylinder.
LACEY
Dundee
Thanks for your reply
Kinda thought that it could be so many things, the mileage is 46,000 it is fine when it’s warn which seems strange, will get the valves checked next fingers crossed it might do the trick
Thanks again
Yes does sound like possible sticking valves due to a buildup of carbon common problem relatively easy to sort possibly in the region of £250-£400 mini specialists may be cheapest.
Looking at this post it may help and a lot cheaper,
if it was me I think I would try it before getting Peugeot involved ££££
Worth a go for maybe £20 and an oil change. ?
Check this out....
viewtopic.php?f=27&t=12673
Cheers M.. :beer:
