Hi guys,
Another nightmare..
My THP 156 is intermitent. Engine light is turning on a few times (showing message that the engine is faulty - repair is necessary). The light might turn ON one day, and after I leave the car resting for a couple of minutes or hours, I turn can on and the engine light just goes OFF as if nothing has passed.
The engine seems to work ok, starts first time always, and seem to pull normal, no matter if the engine light is ON or OFF.
I'm just worried if this could be something related with the timing chain problem. Car is 67k miles and never changed it.
I've checked the error via OBD and it shows the error P0016, which says: "Crankshaft position, Camshaft position, Correlation Bank 1, Sensor A".
Could it just be a bad sensor, or should I start praying and get the chain checked as soon as possible?
As anyone ever experienced this error?
Thanks in advance
Another nightmare..
Thanks in advance
