Engine and tranmission swap from 2011 PEUGEOT 308 1.6 THP 156, EP6CDT (5FV) to RCZ
rajindergill
Malaysia
Good evening Guys and Galls
I currently own a 2011 PEUGEOT 308 1.6 THP 156, EP6CDT (5FV) which is in great condition
Since I have maintained it well and runs great with 100k km did the norm valve seal ,HPFP Thermostat and others
It was rear ended quite bad and its not worth repairing..
I found a 2011 Rcz with the same engine and 6 speed.. Going for a song with damaged engine and other issue .. The body and the interior are in great condition
It is possible
1, To swap the whole front end subframe with engine, transmission wheels, suspension and Ecu to the RCZ
2. Would I have and issue with the instrument cluster and the can bus and Ecu
3. Keys are not available for the RCZ . so what option I have here with immobilizer or will my current Ecu and keys work on the RCZ
4. Can i use the RCZ wiring harnes
Appreciate all you input and advise before I commit on the RCZ
Thank You
Regards
