Drl lights & Philips extreme vision.
Hi. I fitted some Philips extreme vision h7 bulbs & drl 18 led bulbs yesterday. The drl bulbs look great in the day . A very bright white but at night they are very blue. Not matching the Philips extreme vision . Can anyone advise me which drl bulbs to fit so they match the h7. :helpme:
you need the 380/60 smds led drls from rczperformance, these are pure white non blue
Hi there i just ordered the 380 92 smd led bulb will it still fit my rcz ok? or should i have went with the 380 60.. :helpme:
If you got them from Steven at RCZ performance then they will fit. If you are in doubt PM him for advice and a possible change of order, as I see our lighting expert (jassy) does recommend the 380 60 and he does know his bulbs.
Re: Drl lights & Philips extreme vision.
Nope you've gone for the right ones if they're for the sidelight as far as I can recall from buying and fitting them to my own. However, Jassy is the lighting king and he'll be able to tell you for definite.
I bought these originally but had a problem with the passenger one not working. I think that was just my car. They are just a little but more tricky to fit too. Got the 60 ones and they have been fine.
The 380/90 smds are brighter than the 380/60's.The 380/60 are NON CANBUS ie no built in resistor these work well with all rcz,the 380/90 smds are of the Canbus type built in resistors and dont work that well on some rcz ie they dont dim
THE 380/90 are physically larger than the the 380/60 making them harder to fit as they are longer long bulbs
My advice would be go for the 380/60 for the front drls in white and ALSO go for the 380/90 in RED FOR THE REAR STOP/START lights as these are far prettier and brighter than the standard stop/start bulbs brake lights really :thumbup:
RCZ-Performance
Banbury
I do not have an order for the 92's ??? 92's will fit although with some RCZ's they can be very difficult and some what nearly impossible, and if this is the case the 60's are recommended.
Sent from my GT-I9100 using Tapatalk 2
RCZ-Performance
Banbury
And we have all of these bulbs ;-)
Fitted the 380/60 led which i purchased from Rcz performance . So easy to fit and look really well. Thanks jassy06 for recommending them. :thumbup:
Just ordered these too. Hope they aren't too difficult to fit as I'm useless at anything DIY related.
They're a fidgety thing to change to be honest with you but it's well worth the time and the patience! One piece of advice, set aside plenty of time and be prepared to walk away and come back to it!
One tip check they are working properly before fitting them back into the headlamp housing as they can a bit fiddly to get them back out if dont work as you can get some duffer's :lol: but the 380/60's are physically a bit smaller than the long 92 smd's
Noted - thanks both. Hopefully I'll get them delivered at some point in the week and ill have a go on Saturday morning!
The 60s are easy to fit as they are the same size as the OEM lights. Just ask my husband..... ;)
Hi just an update on fitting led 380 92 smd drls.. can be a little bit tricky to fit, i find if you push the light holder forward a bit it gives you that bit extra room to get bulb through.Had a bit of a problem with the passenger side bulb switching on and off but seems to be working ok now! what is the best headlight bulb now to match the led 380 92 smd drls? Thanks for all your information folks.. :thumbup:
