Ricardo_Z
- Joined
- Oct 5, 2019
- Messages
- 26
- Reaction score
- 32
- Points
- 13
Here's the story...
I do a very short commute to work in my HDi RCZ which I know is bad as the engine never gets warm. I had the now fairly regular 'diesel particulate filter risk of blocking' warning message and took the car for a long blast which unfortunately did not clear the message this time. However, the fuel tank was less than a quarter full (80 mile range) and I read this wasn't enough for DPF regeneration (?).
What happened during the drive is the engine management light also popped up and I lost power over 2000rpm but the car is still driveable. Got the guys at work to scan and clear the faults, but the same dashboard messages appeared again after 2 minutes of driving.
I've attached an image from the diagnostic scanner.
I presume the EML came on because of the DPF warning? If I go to my Peugeot dealer they are going to charge me around £85 + VAT to scan the faults again before they even start to sort the issue out! Do I get a DPF flush? Halfords charge £85 for 'partially blocked' filters.
Any thoughts on what my next move should be and should I stop driving the car?
The problem is I can't run the car to regenerate the DPF with the EML on.
