GPS Speed:
GPS receivers display speed and calculate the speed using algorithms in the Kalman filter. Most receivers compute speed by a combination of movement per unit time and computing the doppler shift in the pseudo range signals from the satellites. The speed is smoothed and not instantaneous speed.
HOW ACCURATE IS THE SPEED READING?
From the NAVSTAR GPS User Equipment Introduction document Section 3.7:
GPS receivers typically calculate velocity by measuring the frequency shift (Doppler shift) of the GPS D-band carrier(s). Velocity accuracy can be scenario dependent, (multipath, obstructed sky view from the dash of a car, mountains, city canyons, bad DOP) but 0.2 m/sec per axis (95%) is achievable for PPS and SPS velocity accuracy is the same as PPS when SA is off.
Velocity measured by a GPS is inherently 3 dimension, but consumer GPS receivers only report 2D (horizontal) speed on their readout. Garmin's specifications quote 0.1mph accuracy but due to signal degredation problems noted above, perhaps 0.5mph accuracy in typical automobile applications could be possible.
Getting the accuracy to within .5mph requires a number of dominoes all to be lined up. It is often difficult for this to be achieved and as a result GPS speed accuracy can vary quite a bit.
I am not denying that they are capable of great accuracy, my life depends on them. However don't be lulled into believing the GPS speed is 100% accurate 100% of the time......
I would not be relying on one to save me from a speeding ticket..... :dance:
