Coolant level warning light
Pinkefo
Oban
Hello
I'm new here and looking for a bit of advice. I have a 2012 RCZ and know nothing about mechanics. The coolant level warning light kept coming on when I started the car and intermittently after that. The levels were fine and the garage replaced the sensor (£185) the light is still doing it intermittently and garage advised maybe ECU fault but didn't want to do it in case it didn't work, suggested I call a dealer, nearest one over 100 miles away said they would have to look first, another suggested it may be a broken wire somewhere or an earth problem and I might need an auto electrician.
I see on this seems to be a common fault but I'm not sure how to proceed from here, any advice gratefully accepted.
It's very common and it's down to the sensor to the bottle easy way to check it out is unplug the sensor and see if the light goes out
Pinkefo
Oban
Thank you - but I made an error in my post - the garage renewed the sensor not the filter!
Mikefrank
Swansea
I had same problem with mine I was told to only go for genuine Peugeot sensor….and I still get the warning message…
Ive had my Rcz a few years now as much as I love the car…I’ve never seen no other cars with as many warning messages….😫
Pinkefo
Oban
So you just drive around ignoring it? It is worrying but as it first comes on when I start the car and there is coolant I'm tempted .... ;)
Mikefrank
Swansea
I unplugged it...not a wise thing to do but message was just pain in the as....
Always check oil and water on these weekly though...
Pinkefo
Oban
Following on from all the info from you I have uploaded photos of what's coming up - also noticed my dipstick has broken so don't know if the could affect it (clutching at straws :))5EC49042-98C6-432A-AA83-34F32DB3FAF3.jpeg
Mikefrank
Swansea
Aww hell totally different from what I was posting mine was low water level...but water temperature was fine...Above photos look like over heating
Pinkefo
Oban
Thanks, I'm at loss now - it comes on when I just start the car so I don't think it's overheating - can I repost those pictures somehow not sure as a newbie
Thermostat is one of the main culprits affects the gauge etc
The cooling fan motor resistor can cause the temperature warnings too, common failure and cheap to replace
