Combination window switch for 2013
Ingrid Proctor
Tauranga
Hi there, what is the general price for a window combination switch my window part snapped within?
They’re not too bad secondhand anything new is usually silly but eBay usually have a few offerings for around £40
Ingrid Proctor
Tauranga
Having issue finding right one for my RCZ 04 2013 peugeot. Lots around but backing different. Tried second hand in new Zealand nothing.
There are different switches for different Peugeots that look the same can you post some photos? And if you lift the switch out it will have the serial numbers on it Mr Les Verminator is your man for this he has a number of these switches after chasing a regulator problem.
The RCZ driver side is a different switch to outer Peugeots because of the folding mirror option.
Is your car left or right hand drive?
Ingrid Proctor
Tauranga
My car is a right hand drive. It's the component in main right hand drivers switch. Attached photos. Part number 30170374R. Photo has this and other numbers on.
Appreciate any help locating switch.
The one that you require is ending 921z other end in 922z window Switch...as 2013/2014 was face-lift model and parts number change
Ingrid Proctor
Tauranga
If the electric parts all good. Could I get a cover that is same with the window switches and just put that onto original base?
You’ll probably have to buy the whole switch. They’re readily available over here in the UK via breakers
You would have to check numbers first though
EddieJ
Belfast
You’ll probably end up with a complete unit, I think the buttons all go to one pcb as it’s one plug into the the back of it.
The glass tipping mechanism can be got from Ali, not sure on quality but I did buy a passenger side window switch and have no issues. The glass mount motor mech comes in two types, the 3 pin below and a 6/8 pin if you scroll on thru a bit.
