Can somebody please help with a lighting dilemma
Citoyendumonde
Vancouver Island
I live in Canada, where cars drive on the right hand side of the road (like on the continent in Europe). I purchased a 2011 RCZ 200 hp in Japan where cars drive on the left hand side of the road (like in Britain) and have now imported it to Canada. I was aware that I would likely need to replace the headlight units to get the correct illumination pattern to be able to pass my MOT. All cars in Canada must also have DRL's. While awaiting the arrival of the car, I therefore ordered what I was led to believe to be the correct halogen headlight units for right hand traffic. It turns out my car was one of the rarer cars that came fitted with HID headlights from the factory. I have searched for the last month for a pair of HID RHT headlights, but they are vaporware and cannot be found anywhere. The OEM headlights were made by AL (now Marelli) and even Marelli themselves say that they have not been available for close to a decade.
I have therefore thought about two possible solutions
1.) The RHT halogen headlights that I ordered would be ok to pass the MOT for illumination pattern but they cannot be wired up to the existing wiring harness. My mechanic says that he could rewire the car to the halogen headlights but that this will almost certainly trigger a headlight warning which will cause an MOT failure. He also says that the DRL's on the halogen headlights would probably also not work using the OEM wiring harness that simply bypasses the ballast. Does anybody know if it is possible to get a wiring harness for Halogen lights that will work for the DRL's and not set of dashboard light?
2.) Another option would be to open up the HID headlights still on the car and replace the LHT projectors for RHT projectors. The projectors are the headlight part that determines whether the illumination pattern is RHT or LHT. This would let me keep the better HID headlights but the seal of the headlights would potentially be compromised. I also do not know whether it is possible to find the correct RHT projector once the headlight is opened up. Does anybody therefore know which projectors are used in the OEM HID headlights and where RHT projectors can be found?
Any help or guidance would be greatly appreciated. The car is currently sitting in a garage forecourt and cannot be MOTed/registered until a solution is found.
EddieJ
Belfast
Did you manage to get sorted? I can’t offer any advise, just hoping you got there somehow so you can get onto the fun part of driving you new toy.
Griffy
kettering
sorry bit too technical for m - just like to say that I am impressed that u love the car so much that u imported the car from Japan to Canada :)
Personally, I dont know of a prettier pre-driven car under $100,000 :)
CanuckRCZ
Ontario, Canada
I'm looking for a same solution for the JDM RCZ I just imported to Canada as well. It's surprising how many RHD HID headlights are available on eBay, but so few LHD versions.
Rewire is probably your only option like in all modern cars everything is preprogramed into their designs in some older marques you could find odd sockets in looms for adding additional extras like fog lights etc without breaking into the wiring & just adding relays in the spaces left over in the fuse box not any more today its a case of go & get your laptop or scanner to find or reset a computer fault
Citoyendumonde
Vancouver Island
As shared with CanuckRCZ, I ended up opening up the headlight unit and purchased new projectors. The Projectors are E46R projectors that can be purchased without too much difficulty and can be sourced with Euro or DOT beam pattern in RHT or LHT. The unfortunate thing is that this is time-consuming and you have the risk that you don't get a perfect seal when resealing. You need to apply a new butyl seal between the front and back of the headlight unit.
Now for the more interesting news: the OEM headlights fitted in the cars sold in Japan have a spring-loaded shutter that can be reached with great difficulty when the headlights are fitted. The shutter switches from the overt LHT beam pattern to a more or less flat beam pattern. My headlights were already open so I went ahead with installation of the new projectors, but had I not opened them yet, I would have switched the shutter and attempted to get the MOT. I am convinced that with the alternate shutter position, I would have been successful.
