Problem with the fan.
Bryan Taylor
Ainsdale, Southport, Merseyside.
I have a Peugeot RCZ 1600 petrol and as soon as I turn the ignition on the fan starts up and stays on for the whole journey.
This has flattened the battery on 5 occasions. How do I stop this from happening?
Faulty temp sensors can create this fault amongst others.
Yes and it's a cheap fix if you do it yourself as it's somewhere under the air box about £40 for the part hope this helps..
tabpops
I replaced the temp sensor which cured this problem....for a few months. For now I've removed the fuse that controls the fan. The AC doesn't work (can live without that) but the temp gauge doesn't exceed it's normal reading. A warning comes up everytime I start the car but it's better than a flat battery, which I've suffered from due to the fan problem. Apparently, according to my local garage, Peugeots are notorious for electrical problems. So I'm wondering if it actually is the temp sensor or, as I suspect, something else.
Hi there now I think you will need to do a BSI reset there is a way to carry it out on here DKZ5745 has posted it several times and it's been a success for those who have done it. So please look for his post.
Goatz
London
Hi Tabpops, did you find the cause in the end?
Goatz
London
Fan comes on from start
temp gauge Seems work, just takes a long time but thats probably down to the uk weather.
Michelle
Newcastle upon Tyne
My car has just started doing this. I had a sensor replaced on Friday but today when I have gone to work, the same happened again! Grr
David Morghen
Hi and what fuse was that plz
Covice
Midlands
Hi you set the fan stain on from the moment you turn the ignition I’ve experienced this with mine and other engines and if it isn’t for a faulty sensor which is more unlikely not the answer is pretty simple you have in your water system there are two bleed nipples on your Engine one at the very back at the heater matrix and one on the right hand side of the engine by the water housing if you open up these release the air your fan will stop coming on unnecessary This is how it’s worked out in my experience is fine now
