Windscreen Washers not working 2014 RCZ
Johnmac
Inverclyde
Hi I'm asking on behalf of a neighbour so I'm hoping this is the right section. A couple of days ago the windscreen washers stopped working. We had a quick look tonight. The wipers come in but there is no washer fluid hitting the screen. The 10A fuse is ok. There is no pump "noise". Is it likely to be the motor? Is that a common issue?
Not heard of a Motor failing but it can happen on most cars over the years I've changed a few in Fiats is it possible the fluid was frozen ?
It could be Gunged up with residue & the outlet pipe blocked hence pump failure
ONLY AEK
greece
i know its not the correct thread but i need some help
i have a leakage from the bottle where the water for the windscreen washers goes
A new one has 125 euro!!!!!!!!!!!
How do i search it on ebay?
I mean how is it called in English?
Thank you
OkeyStokey
Thank you
Bottle or reservoir
Look for "Windscreen washer Reservoir" also sometimes called a bottle or tank
Thank you
Ive just found this I’m thinking it will be the same part
ONLY AEK
greece
apparently the dealers on ebay think that the washer tank is made from gold
also the non dealers seem to have a problem to post outside uk, i can't undrestand why
Luckilly i found a second hand tank near my area from a 2009 peugeot 308 for a normal price
the part number seems the same so probably problem solved
