Window motor suddenly only goes down, but not up
Fabianracing
Netherlands
Hi!
After the window mechanism on the left hand side of my RCZ broke I replaced it with a new one. After installing it was shortly functional and went up and down. But after going all the way down it won't go up anymore. I checked the fuses. Replaced the window buttons completely. The final thing I tried is to run the window motor on its own. Giving the result in the video. It does spin down, but when i push up it shortly clicks and stops. What could be the problem?
The circuit board in the regulator one of the capacitors will be on the way out and needs testing
rczpali
Watford
Hi all, I have just refitted my regulator . I now see the motor spins and moves window down, however it does not take the window back up when the passenger or drivers door switch is raised . both switches lower. there is a click when trying to raise and then no movement. Is there something I missed on reassembly or a process to follow ? I have tried holding the button down 10 secs.and then up to no avail. Now stuck as its dark and I cant even move the glass manually. ,
rczpali
Watford
Is this within/ attached to the motor unit or the little black box thats attached to the door card ?
rczpali
Watford
It's Slotted into the motor and easy removed as clips in hope this helps you out...
Hi seems like the problem might lie in the circuit board as your suggest. Without any of the cables / regulator frame attached the motor only operates one way. Are these circuit boards available as a seperate part or only as a whole with regulator as seems to be the case from Peugeot Not sure I am proficient enough to diagnose whats wrong or correct the circuitry. On Ebay only seem to have regulators listed as 2010 - 2012 so mk1 . would these fit a facelift or have connectors / pins or the design changed between years. Given the amount of rain I need to get this resolved as every few days the window drops . Looking like I may have to go the main dealer route and get a new one :(
When it happened to me I got second hand regulator and took it out and fitted working great the regulator is fixed via three bolts but only remove two and slacking off the other you can tip the regulator over to swap the circuit board easy and safely... Hope this helps you out.
